I have problem whith my Gt premium mustang
RE: I have problem whith my Gt premium mustang
Again, something has caused a failsafe mode. The code you have, P2112 Throttle actuator control system - stuck close ON 1 CCM is indicating the failsafe. It may not be the problem for the failsafe, but rather the result of the failsafe because that is exactly what failsafe does. It cuts off the actuator. Check all of your connections to the maf and the throttle body. I will ask again - Do you have a handheld tuner, like a Diablo or SCTII? Were you changing the factory tune? Did this just happen for no reason, like while you were driving? There are a hundred things that could cause the failsafe mode as it is how the car protects itself from damage. It keeps you from blowing the thing up. Are your o2 sensors all connected? Que Pasa??? I am sure we can run you're VIN to see if is a stloen car from the U.S. [>:]
THIS IS THE NUMBER OF VIN 1ZVFT82H355107182 FORD MUSTANG GT PREMIUM YEAR 2005.EL FAILURE To HAPPENED When IGNITING The VECHICULO IN The PARQUING I LET ACCELERATE And I AM IGNITED The DTC LIGHT And The FAILURE OF MOTOR IN SECURITY The VEHICULO IS COMPLETELY ORIGINAL OF FORD
ORIGINAL: MusiccityGT
¿Usted instaló cualquier cosa, como un cuerpo de la válvula reguladora o un producto del aire frÃ*o?
Music city, and all He does not speak any english, he is using a translator like bablefish. that is why the english is off.
http://babelfish.altavista.com/
En caso de que nosotros no podamos ayudarte a arreglar tu carro, aqui tienes la página web de Ford en España:
http://www.ford.es
En la parte de arriba le puedes poner tu código postal y te daran una lista de concesionarios en tu area, ellos podran ayudarte a quitarle ese código al carro y que funcione normalmente de nuevo. Seria buena idea de todos modos comunicarte con uno de estos concesionarios en caso de que necesites reparar tu carro en el futuro y los mecánicos locales no sepan como arreglarlo.
http://www.ford.es
Ummmm... I give.
Well, if the car is completely stock, it died in the parking lot( I think you said) and you have not changed anything in the program, then you may have a throttle body issue, such as the electric actuator or the T.P.S. sensor. This car being a fly by wire throttle, is very touchy and there are actually two Thottle body sensors that send readings to the Spanish Oak processor. You will likely have to find someone who has a handheld diagnostic unit that can pull the codes out of the EEC unit.
Hello again at all the friends, today in my garage I was watching mustang with the diagnosis PC and it diagnoses two failures to me first already announces yesterday p2112 and the second and I believe that it is but important it is P2104 please I request aid to you from Spain because does not exist factory for this vehiculo I I am tecnico in ferrari and maserati but of vehiculo American is no official importer if somebody can say that to be able to review in engine I to me and reviewed all the connectors all well and this. thanks for your time and sorry for send the post bad
I will translate for them....
HE SAYS
ORIGINAL: dkano
http://www.ford.es
http://www.ford.es
ORIGINAL: dkano
In case that we did not fix your car, here you have the Web page of Ford in Spain: http://www.ford.es In the part of above you can put your postal code and you would get a list to you of shops in your area, they they will be able to help him to clear that code to so that the car works normally again. Serious good idea anyway to communicate with one of these mechanics in case that you need to repair your car in the future and the local mechanics does not know how to fix it.
Golforone,
Si fuera usted lo llevarÃ*a el Ford en España, si usted tiene que pagar coste de la reparación, por lo menos él soy fijo, allÃ* no soy mucho que podemos hacer para usted aquÃ* con fuera de más información apesadumbrada, mi español estoy oxidado puesto que me movÃ* desde Cuba cuando era joven
"In english"
Golforone,
If I were you I would take it to the Ford in spain, if you have to pay repair cost, at least it is fixed, there is not much we can do for you here with out more information. sorry, my spanish is rusty since I moved from Cuba when I was young
"In english"
Golforone,
