overdrive
overdrive
Hi all, this may be a dumb question, but what are the ideal driving conditions to enable or disable OD? or best always on or always off? the manual's description of the feature is quite lacking... thanks...
RE: overdrive
ORIGINAL: ren274u
Just leave it on when driving, turn off when racing, and when you want your rpms higher for spirited driving.
RE: overdrive
[quote]ORIGINAL: dkano
hehe, I like spirited driving all the time, and like the feel with it off... is there any downside to leaving it off always besides decreased fuel efficiency?
ORIGINAL: ren274u
RE: overdrive
[quote]ORIGINAL: 05gtrules
ORIGINAL: dkano
ORIGINAL: ren274u
RE: overdrive
ORIGINAL: dkano
Exactly. My car feels completely different when I turn the overdrive off and start pushing it, the 3.90 gears made that difference even greater now! Next time I go to the track I'm going to try to do a couple of runs with overdrive on and then turn it off and do a couple of more runs, see what the difference would be.
ORIGINAL: ren274u
RE: overdrive
The transmission is computer controlled to shift at the optimum points... Shifting manually, and hitting the OD switch will do nothing for your times... You're best bet is to leave it in D with the OD on....
RE: overdrive
lol with overdrive on you use 5th... with it off you dont use 5th
lol in the case of races and downshifting... when throtle pressure over comes governer pressure your car downshifts. as you rev out governer pressure then over comes throtle pressure and shifts. then it does it over untill you run out of gears.. whether its on or off is irrelevant.. you can be in 5th hit the throtle to the floor, it could downshift to 3rd then do its thing as you rev out through each gear... overdrive off... your in 4th gear with an initial higher rpm at the same speed you were in 5th, you pin the throtle it downshifts to 3rd and it does its thing back to 4th.. except over drive is off.. so youll just rev out in 4th gear... oeverdrive on or off doesnt change yuor gearing.. so in no way it would make a difference if your racing or not
