Nokya Arctic White H13
Nokya Arctic White H13 1 7000 deg 100/80w replacing 60/55 headlight bulbs
they seem to be brighter than stock bulbs definately cast a "bluer" light on the road
...wonder how long they will last.
install hints: clean bulbs w/ alcohol before installing then do NOT touch; make sure the red rubber washer comes out w/ each old bulb and the new supplied washers are installed w/ new bulbs. i struggled and finally got R bulb in...VERY tight when cleaning up noticed i had put new AND old washer on R...when i pulled one washer off it went in as easily as the L one. i probably shouldn't be let near a wrench....
p. 36 in owner's manual
Shipping Type:
Shipping Total: $6.91
Payment Type: Credit_Card
Tax Total: $0.00
Order Total: $56.90
Product 1:
Item ID: 7228
Description: Nokya Arctic White H13
Qty: 1
reply to subsequent e-mail:
No you do not need anything else Mustangs are built Ford tough!
See you in the dark!
Andrew
Sales@coolbulbs.com
www.Coolbulbs.com
On Mar 30, 2006, at 11:59 PM, r3com wrote:
Order submitted on 3/30/2006 11:40:59 PM
7228 H13 Hi 100/80 $49.99
Order Details:
Part#: Product: Quantity:
7228 Nokya Arctic White H13 1
for my 2005 Mustang GT Premium
do i need the heavy duty wiring harness??
where would i get and how much?
Shipping Type:
Tax Total: $0.00
Order Total: $56.90
Product 1:
Item ID: 7228
Qty: 1
Andrew
Sales@coolbulbs.com
www.Coolbulbs.com
Order Details:
RE: Nokya Arctic White H13
You should keep an eye on those bulbs. At almost double the wattage, I can almost guarantee you are going to melt something. Either wiring, the housing, etc. I absolutely guarantee you will lose the small reflector that covers the front of the bulb. It is only glued on and due to the extra heat from the high wattage bulbs, it melts the glue and that piece will be rolling around in the headlights forever! Do a search, lots of people had the same problem!
breaking
10-02-2015 01:27 PM
