h pipe
just install new off road h pipe to day have a ? it makes this metalic sound around 3000 and at wot is this normal or do i need to get back under and do some more ajustments it looked like i had no rubbing going on
Check your heat shields. The ones that look kinda like aluminum foil tacked between the exaust and the tunnel. Those things make a terrible mettalic sound when tapped or vibrating. Maybe they are bent or resonance is causing them to vibrate a bit.
Well... I'm going to say check your mufflers where they attach to the over-axel pipe. I'm thinking it's the over-axel pipe connection at the mufflers.
When I put my h-pype on I moved my over-axel some how and my mufflers wouldn't stay clamped to the over-axel pipe. Couldn't really tell by looking at it, but I tightened and adjusted my mufflers so many times until I realized the over-axel pipe didn't look right. So I loosened everything from the h-pype to over-axel pipe connection and the mufflers. Got everything to fit easy, without having to push and pull. Then tightened up everywhere. Everything will move quite a bit.
Sep 24, 2015 09:18 PM
trashxtrash
Sep 20, 2015 10:49 PM
