Need Help with Pro 5.0 install
Old Apr 18, 2006 | 05:00 AM
JAAAM's Avatar
JAAAM
Default Need Help with Pro 5.0 install
Ok...
I know this was suppose to be an easy install and it was but the damn thing won't shift into 5th or reverse.
1st - 4th work fine. The long bushing is on the driver's side. I was given no instructions.
Do I have something out of order? Can someone provide the instructions.
I haven't forced anything together so I'm sure the shifting forks are ok. There was a bolt that was provided
with the shifter that seems to have no home? Is this used to center the bushings?
Old Apr 18, 2006 | 10:02 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Need Help with Pro 5.0 install
Possibly try loosening the but on the bottom where the shifter connects to the shift rod.
Mine didn't come with instructions either, I had to contact Pro 5.0 and have them send it to me. Installed without them but wanted to check my work.
Old Apr 18, 2006 | 12:11 PM
MusiccityGT's Avatar
MusiccityGT
Mine was hard to get over to 5th and R at first, but has eased up over time. It is hard to mess up the actual install. [&:]
Old Apr 18, 2006 | 12:22 PM
MusiccityGT
Old Apr 18, 2006 | 12:23 PM
MusiccityGT
ORIGINAL: MusiccityGT
Thats what happens when you walk away from the computer and don't remember if you hit send already. [8D]
Old Apr 18, 2006 | 02:12 PM
JAAAM's Avatar
JAAAM
I called pro 5.0. They had me take the shift rod off the shifter and wiggle it around. Guess it was bound at the place it engages the tranny.
Put it back together and its all better now. Thanks for your replies.
It's still a little tight around 5 & R but can that thing nail the 2-3 shift.
Did you guys adjust the stoppers to be just short of the stick or just touching the stick?
The shifter is kind of noisy but has amazing shift engagment.
Old Apr 18, 2006 | 02:58 PM
hawgman's Avatar
hawgman
I ♥ Acer
The stops are supposed to be 1/16th inch off of the shifter handle.
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
