How to get to 12's?
#23
RE: How to get to 12's?
geez guys now i think there is something wrong with my car. 757 ran 12.80's with stock tires and stock converter...i've only run 12.62 with bogarts and a TCI converter. time to go back to the dyno somethings wrong.
#24
ORIGINAL: 1QuickShortBus
Gee NHRA rules dictate a Roots style blower, but that is apples to oranges we are talking street cars not 4 sec top fuelers.
I can't give exact numbers yet out of respect for PowerHouse while they finalize the kit, but I will say it easily exceeds what you would see out of any supercharger at similar boost numbers on an otherwise stock car (including mufflers).
I'm sorry but I have better things to do than argue with people that won't listen because they think turbos are only for imports and they don't know the first thing about forced induction. I know of at least one individual that is ditching his Procharger in favor of a turbo on an '05.
Show me one other S197 that has run 10.60's at 131mph on a stock block, trans, clutch etc in a full weight car. PowerHouse has over 100 passes at this power level in their car.
There is someone who has a twin-turbo Ford GT now, and i'm sure if he could have got the same results from a s/c he would have gotten that. The fact is though that tubo's are more efficient because they use "wasted" energy from the exhaust for their power. On the other hand, a turbocharger causes some amount of back pressure in the exhaust system and tends to provide less boost until the engine is running at higher RPMs. Superchargers are easier to install but tend to be more expensive. Turbos are also known for their unique ability to spin to incredibly high rpms and make outrages peak boost figures (25psi+). While operating a turbocharger at very high levels of boost requires major modifications to the rest of the engine, the turbo is capable of producing more peak power than superchargers. Turbo's will also give you the most usable horsepower between 2500 and 5000 rpm. In an acceleration contest, the tubo will beat any type of s/c because massive midrange torque production.
When comparing supercharging and turbocharging systems and weighing out your options on what to buy to make your high-performance street machine faster, you must take into account the efficiency, reliability, versatility, and cost of your options. If you choose to do so, you will undoubtedly see the overwhelming superiority of turbocharging to supercharging. Time and time again(I've seen it personally), turbocharged cars have given out beatings to supercharged cars, and until the majority of racers start seeing through the "facade"(used a dictionary for that one lol) created by supercharger companies to cover up their shortcomings.
With having a turbo also means more up-keep. Because turbo's run at such high temperatures it also makes the forced air warnmer which is exactly what you don't want happening, but an intercooler will solve that problem. Turbo's also feed on fresh oil constantly, so oils with high ratings must be used in the vehicle. You also have to warm up the turbo's before agressive driving, and they have to cool down at idle for about 2-3 minues after driving hard.
Some people see "turbo lag" as a bad thing, but when you are launching your car from a dead stop, the lag will give the car time to get the traction it needs, then when the boost kicks in it will launch, whereas s/c's are more likely to spin the tires, which in effect is why turbo's are so good at launching.
With that being said supercharger's are probably the best and easiest way to get good hp, but if your looking for high hp#'s, the single and twin-turbo set-up's will beat any s/c application.
I hope this information is correct, and I hope I changed some of your minds.
#26
ORIGINAL: mustangman2424
#28
LOL were you agreeing or disagreeing with what I said 1QuickShortBus?
I meant to say supercharger's are probably the best and easiest way to get good hp because they are easiest to install and they don't require welding or anything, but if you are experienced with welding and such, or you have extra $ to have a shop install the turbo, then either one is a great choice. I also said that the turbo's ARE cheaper than a s/c.
#29
#30
ORIGINAL: ren274u
It is confirmed tonight i ran 12.89@106 if only i had some better tires, i could get my 60ft under 1.94. Then i wonder what i would run. I guess that offroad X helped take off .2
