New tires for 20" wheels
I have 20" wheels on my 05 GT mustang and was wondering what the widest tire is i can go with. I bought the car with the wheels on them and have looked all over the wheels and do see where it says how wide they are. I measured the width of the wheel and it was a little over 9" from lip to lip. I am wanting to run 275/35 on the back. Do you think they will fit?
RE: New tires for 20" wheels
i have 20's on my mustang gt and have Pirelli 275/35ZR20's in the front and 275/40ZR20's in the back, i think thats as wide as you can get, unless someone can prove me wrong
hope that helps
hope that helps
With the proper offsets you should be able to run 275/40/20 in the front and 295/40/20 in the rear lowered without issues. I am running 285/30/20's in the rear and still have room for a wider / taller tire.
There is a Saleen on eBay with 20x10 wheels on the rear with 315/35R20 rubber.
[IMG]local://upfiles/37781/0590F13693B64521A8A2F2991866CF27.jpg[/IMG]
[IMG]local://upfiles/37781/51E80B4A4DE749638C9318410192C22C.jpg[/IMG]
Those arent 315/35r 20 on that saleen. Those look like the stock tires on the saleen, I was told unless I get off set rims the stock tires on a saleen is about as wide as you can go, you can go a little taller.
I put 11.5" x 20" wheels on the rear. It works fine. The only tire I can find to fit is 305 25 20. I'd like a little taller tire, but no one I can find makes one.
Hmm...Apparently I wasn't paying attention to the posts. I'm going to check out the Pirellis that Tmac has.
09-16-2015 07:53 PM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
