Shift points
Old Jun 13, 2006 | 04:35 PM
Sleeper05's Avatar
Sleeper05
Default RE: Shift points
ORIGINAL: ski
One forum member finds that shifting at 6500 rpm works best for him at the 1/4 mile drag strip. His naturally aspirated Mustang GT has a modified tune, CAI, and a few other bolt-ons, but uses stock tires and a stock gear, and it has a best time of approx. 12.6 sec. so far. He said that shifting at that rpm allows him to cross the finish line in 3rd gear, whereas using a lower rpm shift point would increase his e.t. by forcing him to shift into 4th before finishing.
wow, in 3rd gear running that time???
im into redline in 4th gear by the time i cross the line. i shift high to maximize my power curve in each gear considering i use the meat of the torque band and up to peak hp points in 4th anyway with 4.30s.
Old Jun 14, 2006 | 02:29 AM
chevykiller's Avatar
chevykiller
I ♥ Acer
ORIGINAL: modular81
Find what rpm's your car makes it peak hp at and set your shift points 200-300 rpms above that. Usually that will yield the lowest et's at the track, at least for me it does.
You're almost right, just backwards. You should set your shift points 200-400 rpms BEFORE your peak and use a shift light. The reaction time of actually shifting has to be factored. Your goal is to shift dead on your peak HP curve.
There is no single shift point(s) to give because there are so many factors with GEARS being the biggie. I don't care what set-up you have, you are not passing the traps in 3rd with 4.10's+ unless your running in the 18's...lol
Every set-up is unique. You have to get on a dyno and see your HP curve and then you'll know for sure, no guesswork, just facts.
Mark
Old Jun 14, 2006 | 11:03 AM
ski's Avatar
ski
ORIGINAL: Sleeper05
Here's a link to his posts. Also, he ran a 12.9, and not a 12.6. My mistake.
https://mustangforums.com/m_1420619/tm.htm
Old Jun 14, 2006 | 11:14 AM
Dan64456's Avatar
Dan64456
yea the dash sais the redline is 6000... Thats awesome how you can take these eninges higher! I am still scared to tho... I had it up to 6250 once... I guess I shouldn't worry?
Old Jun 14, 2006 | 04:11 PM
Sleeper05's Avatar
Sleeper05
ORIGINAL: Dan64456
as long as the engine has load on it, you don't keep the rpms up there for an extended period (ie, SHIFT), and you don't tach out all the time, its not bad for the motor. to a very slight degree, it can even be good for the motor on occasion under certain circumstances
edit: ski--ya 12.9 makes sense...i was gonna say that 12.6 on stock gearing (other than that one shop that did it with just intake and slicks) would take enough mods that you'd be trapping a lot more than 3rd gear could handle!
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
