Stock GT Auto Burn Out?
RE: Stock GT Auto Burn Out?
ORIGINAL: EasyGT
do you need a tune if you get a K&N CAI? and what is a tune, im still learning so im confused.
ORIGINAL: ral8667
06GT4RAD,
Thanks for the feedback. I'm not really wanting to burn out all that much. There's a guy I work with that gives me a hard time saying that the car can't break loose. Anyway, since it really can't as an auto without any mods, I thought it would be fun to try out power breaking. One of these day's I'll give it a try in a parking lot. Thanks for the instruction...
Ron
06GT4RAD,
Ron
I got the K&N first and later the tune because of money. I did see a diffrence with both. More with the tune. The shift firmness and throttle response alone, along with more power.
If you have 18in BFG's and a auto, the gearing with them makes it hard even with the CAI and tune and turning the traction control off to burn the tires off. Sure it will be squeeking them all the way through frist and bark them hard into 2nd, but not just burn the tires by no means. Step on the brake and ease it to 2000rpm then mash it and let go is a whole diffrent story.
one thing you guys are forgetting is to put it in either first or second gear manually so it wont allow it to shift, if it shifts while not moving the tires could stop and you could seriously damage your tranny, if you shift while you are taking off or moving while burning out or chirping second gear that is not as much harm
and you should be able to do that and get on the break enough to keep the car from moving then come down on the gas, and adjust the break as needed, also when you are done if you go 1-2-3-OD off D you should be able to atleast chirp second gear if not third, cause even my stock 02 V-6 will put a strip down doing that
Thanks for all of the replies on this topic. I appreciate the advice from everyone on this forum. It's amazing how much you can learn here. My wife laughs at me reading this forum every night since we got the new car. But there's so much to read!!!
Gotta to run and buy another gallon of milk. (Ya know, just some excuse to go and drive the car again...)
Take care.
Take care.
