Gears!!!!
RE: Gears!!!!
I haven't changed the gears yet and I'm only getting 21 miles to the gallon on the highway, putting in 3:73 in next week any way. Just have to enjoy yourself.
[IMG]local://upfiles/40542/76C9861EAEE84B7DBCE701D7A95653D5.jpg[/IMG]
RE: Gears!!!!
Maybe your car isn't broken in and a course if you drove drive at sea level your mileage could vary.
ORIGINAL: Just4fun
RE: Gears!!!!
ORIGINAL: rjgstang
if your car has 3.55 stock why would you not go 4.10 at least?
RE: Gears!!!!
Guys, this is really easy to figure out.
When you change gears, it's all a matter of the difference between your current ratio and your new ratio, which is easily calculated by means of percentage. For example, if you have 3.55s and you switch to 4.10's, then the percentage change is (4.10- 3.55) / 3.55, or about 15.5%.
This means that your acceleration will go UP by 15.5%, and your engine RPM will also go up by the same 15.5% (That's where the extra torque comes from) Fuel mileage isn't exactly linear with respect to RPM, but it's close enough. You're mileage will go DOWN by the same figure: 15.5%, assuming your driving habits don't change.
So, if you're getting 26 MPG highway now, you will be getting approximatley 22.1 after the swap.
The impact on city driving probably won't be as bad, becasue you can shift into higher gears "earlier" than you previously did.
Oh, and the SCT-II tuner will correct your speedo for gear ratios as well.
RE: Gears!!!!
ORIGINAL: viking396
What is the motor turning at driving at 65?
ORIGINAL: cableguymicah
Well when I had my 3.73 I got 18---dont drive much, plus never highway--with my 4.10's I get 14
When I had 3.73 3rd gear at 65mph was about 3k rpm-- though usually switch gears around 3k drving normal--with the 4.10's its about 3500l rpm at 65 in third gear
RE: Gears!!!!
T-3650 (5 speed) have a 5th gear ratio of .68, so my $.02, 4.30s but 4.10s will be fine as well, 3.73s are a waste on the T-3650, even with a blower
Gear Calculator
Gear Calculator
