Adjustable upper CA needed?
Old Jun 27, 2006 | 03:25 PM
blowngt's Avatar
blowngt
I ♥ Acer
Default Adjustable upper CA needed?
If you are getting an aftermarket upper CA will it effect the pinion angle and cause vibration with an aluminum drive shaft? I have heard you need to get the adjustable to prevent this. Is this true?
Old Jun 27, 2006 | 04:18 PM
MusiccityGT's Avatar
MusiccityGT
Default RE: Adjustable upper CA needed?
If it is exact the same length as stock, and you have no plans of changing the ride height, then no. I would recommend getting the adjustable anyway and setting it with an inclinometer, preferably digital. It should be between 3.5 and 4%. I set mine to 3.8% and it is perfect.
Old Jun 27, 2006 | 04:29 PM
blowngt's Avatar
blowngt
I ♥ Acer
TY
JonnyBlazeGT
Nov 3, 2015 01:10 AM
cedarmn
Aug 28, 2015 09:51 PM
StangfireGT
Aug 20, 2015 08:51 AM
defarmer
Aug 13, 2015 06:40 AM
dseg
Aug 8, 2015 09:00 PM
