05 GT Auto...Changing Tranny Fluid
#21
RE: 05 GT Auto...Changing Tranny Fluid
ORIGINAL: VampireStang
exactly..."THE AUTOMATIC TRANSMISSION FLUID IN A VEHICLE SO EQUIPPED (MINE!!!)" My car takes ATF automatic TRANSMISSION FLUID which doesnt need to be changed as requently...manuals use automatic transmission fluid.
and i bolded a few words for you too
ORIGINAL: bl1nkage
Here ya go, you obviously need this more than me http://en.wikipedia.org/wiki/Manual_transmission
If you read it you can find this quote
"Manual transmissions are lubricated with gear oil, which must be changed periodically in some cars, although not as frequently as the automatic transmission fluid in a vehicle so equipped. (Some manufacturers specify that changing the gear oil is never necessary except after transmission work or to rectify a leak.)"
I bolded the important parts since you dont seem to understand very well.
#22
im not dealing with this anymore...my manual transmission does take automatic transmission fluid...if you think im wrong then be happy that ill ruin my tranny putting it in
#23
#24
i havent really checked where to put it in yet but when I drained it it looked/smelled like ATF and it damn sure wasnt gear oil...after some research i found out that it does infact take ATF...im going to put it in the hole on the passenger side of the tranny.
#25
#27
ok ill call FORD today or tomorrow and ask them...ill let you know what they say
#28
it takes ATF look at this site...my tranny is the Tremek3650 (tr3650)
http://www.amsoil.com/products/trans...fluid_rec.aspx
so it does take ATF but at least im sure of myself after all of this...you had my doubling back on myself.
#29
Many manual transmissions now use Automatic Transmission Fluid instead of the old gear oil. My 2000 C5 Corvette that I just sold is a good example. It used ATF in the manual six-speed. I would be quite surprised if the Mustang owner's manual didn't say what the proper fluid is, but since I don't have my Mustang yet, I can't check myself. So in short, yes, some manual transmissions do use ATF fluid, and some use gear oil. Hope that clears it up for you guys.
#30
ORIGINAL: Mustang Buster
