DTC ERROR CODE P2068 NO DATA AVILABLE
Running Flowmaster American Thunder Axle Backs, JLT-II CAI w/ X-Cal-2 Tune. Has any one ever heard of this?
2-Weeks ago when I was pulling into a Parking space and a Beep sounded and I looked on the dash to see Data Flow Error where that "Average MPG and or the Trip Mileage would be Found". So I shut the vehicle down and let it sit for a little over a minute and re-started it. The "Data Flow Code" Dissapeared. Well almost 2 weeks later I hop in my car today and see that the Check Engine Light is on. Well the engine sounds Normal and responds to throttle as normal and is Ideling as normal right in between 800-1000 RPM's. So I get home and throw the X-Cal in and check the DTC Code and it states the above Code P2068 NO DATA Available. Any Ideas or input would be greatly appreciated. Thank You.
RE: DTC ERROR CODE P2068 NO DATA AVILABLE
Straight from the Ford Service manual:
P2068 - Fuel Level Sensor B Circuit High
Description: See the description for DTC P2065.
P2065 - Fuel Level Sensor B Circuit
Description: Fuel level information is sent to the powertrain control module (PCM) on the communication link.
Possible Causes: Communication link concern; Damaged instrument cluster; Damaged smart junction box (SJB); or Damaged PCM
