Kenne Bell BOOST-A-SPARK
Old Jul 11, 2006 | 10:39 PM
Justastockmustang's Avatar
Justastockmustang
Default Kenne Bell BOOST-A-SPARK
Anyone had any experience with the Kenne Bell BOOST-A-SPARK? I just ordered a KB blower and got the boost-a-spark to avoid having to close up the plug gaps. Any good or bad experiences?
Old Jul 12, 2006 | 01:47 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Kenne Bell BOOST-A-SPARK
Wouldn't gapping your plugs have been a lot cheaper?
Old Jul 12, 2006 | 12:09 PM
GhostPony's Avatar
GhostPony
Better solution:
Buy the GMS Coil-Over Packs. They are 60,000 volts and will let you run .045 gap.
They add 25 HP with a blower setup.
This has been proven by dyno tests from several people.
I installed them and they rock! They are not cheap though.
Old Jul 12, 2006 | 12:31 PM
blowngt's Avatar
blowngt
I ♥ Acer
I have been told the BAS does the exact same job as the coil-overs, so good buy IMO. Not really needed unless you are pushing over 500 rwhp IMO. - those doing 500+ are the only ones I have heard of with losing spark issues.
Old Jul 16, 2006 | 01:11 PM
Meangreen1200's Avatar
Meangreen1200
No problems with mine, just one range cooler. Didn't even re-gap.
Old Jul 16, 2006 | 02:26 PM
blowngt's Avatar
blowngt
I ♥ Acer
Oh and in case your wondering, the BAS increases the spark to the plugs 25%. Doesn't matter what gap - it is a flat 25% increase. It is not adjustable or varied. It is not meant as an alternative to gapping plugs. It is meant to do eaxactly what it's name says - INCREASE SPARK. Again, not a neccessary mod unless you are having spark issues which I highly doubt in your case.
Old Jul 16, 2006 | 05:28 PM
jcovercash's Avatar
jcovercash
ORIGINAL: Meangreen1200
Yep Follow KB instructions they KNOW WHAT THEY ARE TALKING ABOUT.
Get a set of 1 heat range colder, leave them at factory gap .045 and your GTG!
Again they know what they are talking about.
Old Jul 17, 2006 | 12:04 AM
Justastockmustang
ORIGINAL: blowngt
The BAS IS adjustable, only activates under boost, is NOT a 25% increase, and CAN increase spark power to prevent a spark from being blown out under boost. Where did you get this info?
Old Jul 17, 2006 | 12:16 AM
Justastockmustang
There are quite a few posts from people with FI that have had to reduce plug gaps to prevent high boost misses at the boost levels I am planning to run. The BAS looks to be an inexpensive and easy to install way to make SURE this is not a problem. KB's tech support agrees. I was just asking if anyone who HAS USED ONE could give any comments.
Old Jul 17, 2006 | 01:14 AM
blowngt's Avatar
blowngt
I ♥ Acer
ORIGINAL: Justastockmustang
ORIGINAL: blowngt
Mike (blowngt) is talking about my car and doesn't quite have the facts right. (yes, I'm using his info right now) Here's the skinny...
I have HTO plugs gapped at .032 and was losing spark at 5800 rpms on 14 psi. The granetelli coils seemed a solution but seemed pricey. I went with the BAS and it worked just fine. I had it set for a 25% boost and I had no spark issues through 6800 rpm. I am finishing up a new motor now with 18-20 psi and plan on setting the boost at 35-40% for a 7400 rpm spin. Gapping the HTO plugs .032-.035 works well enough up to about 530-540 hp at under 13 psi. If you are going to be in those levels, I don't think you will need the BAS. if you exceed them, you probably will.
Hope this helps.
