Last edit by: IB Advertising
Browse all: General Overview
- Ford Mustang V6 and GT 1994 to 2004 General Information and Recommended Maintenance
Important information to help you understand your Ford Mustang.
car feels slower with windows open.
acceleration just doesn't feel nearly as strong; the engine seems to just not have the torque when the windows are open.
is this just a perception thing? if so, why?
RE: car feels slower with windows open.
Could also be all the air coming into the car that is pushing you back a little. I always close the windows when I want to go "fast", do it without thinking about it.
Over about 50mph, you actually loose power, or at least usable power, due to drag. You'll actuall save gas and have more power if you roll up your windows and turn on the a/c.
I saw a study that shows your car will get more MPG with the windows closed and AC on than driving with windows open. (They were testing driving on the highway.) So I figure that is also related to the cars performance on the butt dyno
to maximize MPG, generally speaking, above 50 mph roll windows up and turn on A/C. Below 50 mph, roll windows down. However, there are other factors as well. How many windows are down, and how far down are the main concerns. Remember, you don't need all ur windows down at 60 mph to stay cool, you just need decent air circulation. Halfway down could provide the same cooling effect with less drag...
In any case, it all amounts to less than a MPG difference between AC and windows down anyway (unless you're going like a buck 20) so I say crank up the A/C full blast if you're cruising on the highway!
I personally experienced the change in MPG while on PCH. I thought at the time that having AC on was bad and so kept rolling the window down. I had reset the computer which shows MPG and it would drop about 1 or 1 1/2 MPG when I had the window down. On a recent long trip I noticed no discernible drop in MPG when using AC instead. I used to think that turning it on would cause more tension on the belt, and the expected increase in engine work to maintain a constant speed. Nope!
So what it means is no more sweating it out with just the fan on higher than normal! Go AC Baby!
ORIGINAL: jonnyjon84
A/C on? Doesn't that cause drag?at least in my wifes honda it does; it's like opening a parachute on the Hwy. I honestly haven't had my car long enough to find out, it's in the shop now for the clutch packs and master cylinder leak.
