Engine lowering mounts
Old Aug 12, 2006 | 11:23 PM
Wally39's Avatar
Wally39
Default Engine lowering mounts
Did you guys with the Saleen S/C have to use the engine lowering mounts?
Old Aug 12, 2006 | 11:29 PM
mikefan20's Avatar
mikefan20
Default RE: Engine lowering mounts
there is a really long thread about this if you use the search function. Most say no, that the Saleen will fit under the stock hood. But there is one guy on here with the marks to prove that it doesn't fit under his. There is also info if you decide to go with the lowering mounts. I think his name is CEIKIM or something, sorry for botching the name.
Old Aug 12, 2006 | 11:46 PM
cekim's Avatar
cekim
ORIGINAL: mikefan20
That's me...
There are 3 variations it seems - dependant on manufacturing tolerances (aka slop):
1. fits under the hood without hitting the firewall with tight but functional clearance
2. does not hit the hood but does hit the firewall
- sub variation of it clears until the first dyno pull (OUCH)
3. hits both (that's me...)
So, you might get lucky, you might not... Given that the install procedure is the same before and after the SC - the only compelling reasons to do them before would be:
1. more room to wiggle the unit in - It is a tight fit regardless
2. don't have to wait 3 days for shipping if once you get it in you find you need them
3. if someone else is installing for you, you don't have to go back and/or get a call from them saying you need them...
The mounts have pros and cons - they are stiff which is good and bad - good for holding the engine in place, bad for translating every wiggle of the engine into your seat (though some including me like that kinda thing...)
Old Aug 13, 2006 | 12:28 AM
Wally39's Avatar
Wally39
Thanx. I already have the engine lowering mounts. Maybe I'll do that step last to see if I need them.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
inyadreems
Aug 21, 2015 09:10 AM
classic69FB
Aug 12, 2015 11:58 PM
