Knock sensor logging
Old Sep 11, 2006 | 11:23 PM
Justastockmustang's Avatar
Justastockmustang
Default Knock sensor logging
Anybody know if the SCT XCalibrator will log knock sensor activity?
Know of any other way to log knock activity other than smoke and flame?
Thanks!
Old Sep 12, 2006 | 01:13 AM
howyhowy's Avatar
howyhowy
Default RE: Knock sensor logging
ORIGINAL: Justastockmustang
Thanks!
I just fired up data logging for the first time tonight. Yes it does, but the values are only updated on a once - per second (or abouts) basis.
the options to choose from in this category are:
CYL_1_KNOCK_THRESHOLD
CYL_2_KNOCK_THRESHOLD
CYL_3_KNOCK_THRESHOLD
CYL_4_KNOCK_THRESHOLD
CYL_5_KNOCK_THRESHOLD
CYL_6_KNOCK_THRESHOLD
CYL_7_KNOCK_THRESHOLD
CYL_8_KNOCK_THRESHOLD
KNOCK_SENSOR_1_NOISE
KNOCK_SENSOR_2_NOISE
-howy
Old Sep 12, 2006 | 01:21 AM
Justastockmustang
Thanks!
Unfortunately that update rate would not be very useful for tracking real-time knock, my goal.
You can set knock threshhold on individual cylinders with only two knock sensors?
ORIGINAL: howyhowy
-howy
Old Sep 12, 2006 | 01:32 AM
cekim's Avatar
cekim
In theory, they have to "filter out" combustion noises to know what is a "knock" and what is not...
So, they should know what should be firing at the moment and therefor which one must be pinging...
Can't say I have proof that this is what they did, but it seems logical enough...
If you set the threshold to "1" - do you care exactly which milli-second it occurs?
Old Sep 12, 2006 | 09:27 AM
Justastockmustang
Good point!
ORIGINAL: cekim
So, they should know what should be firing at the moment and therfore which one must be pinging...
If you set the threshold to "1" - do you care exactly which mili-second it occurs?
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
