Brake Problems
Brake Problems
Yesterday I raced a M3 for a long period of time in the highway and I had to stop racing because my front brakes where failing. I was very worried, is this normal??? What upgrade can I do to the brakes and not spend more than $600 I dont have that much $. Thank You
RE: Brake Problems
What kinda of racing? Were you constantly braking from high speeds? If so you might just attribute that to brake fade. It happens to all brakes at some point, but larger brake setups are less suceptible since they have more heat capacity due to more rotor area and usually better heat dissipation through cross-drilling.
RE: Brake Problems
Personally I prefer slotted rotors over cross-drilled rotors seeing how cross-drilled rotors are prone to cracking but that would help your problem. But brake fade is not exactly brake failure, just something that happens as your brakes get hotter and gases build up between the rotor and brake pads reducing your braking ability. Breenspeed sells a stoptech brake upgrade kit that looks pretty attractive for the money and covers all the basics.
RE: Brake Problems
+1 on the pads and lines.
I've only driven on one set of cross-drilled rotors and they might have been out of tolerance but they had developed a couple cracks after about 4 driving sessions (not my car so I don't have any info beyond that).
I am not inclined to do too much testing on the rotors so I'll let others recommend there, but I have heard the lean is slotted vs cross-drilled.
I have tried just about every brake pad out there for our car in both street and track conditions:
The stock pads lasted 6 months of driving and a 2 day driving event but then they did fade quite a bit at the end and then were gone fast - actually not bad I would think for stock pads.
The Hawk pads are very good but I am a little under-joyed with the ceramics as time has gone on verses the hype (they dust a lot more than I was led to believe - I've re-bedded and they still dust a lot). They do grab well and I have not felt any fade...this is the only pad that I have not tried on the track though.
THe HPS+ are a good track pad and the HPS have a better bite than stock.
I ran the EBC reds and greens on the track and even the greens held up - ran one set for ten 30 minutes sessions over two days and they were still quite streetable and had lots of bite left. The EBCs are quite dusty but I probably will switch back to the greens for daily driving over the Hawk pads.
RE: Brake Problems
Hmm....could be a number of things...flat spot on the tire (though you'd notice that other times), uneven wear on the pads or possibly a warped rotor.
Unless someone has a better idea (and I can bet you $ they do ,pPull the pads off and have a look at them and then inspect the rotor.
