CMCV question...
#21
RE: CMCV question...
I would have to agree with both CrazyAl and Rock36. I installed mine this past weekend and have been running as hard as possible, in this area, to see what if anything has changed. No Dyno time yet.. next month.. but the SOTP feels stronger in the mid to high RPM, na dI have noticed no losses in the lower end either.
#22
One more thing... we all might want to invest in an Oil Separator for our cars... seems that the blow by is a little messy in there. Below are some pics of my stock plates after 43K miles.. Steeda has them for $69.00 EBay for around $30.00.
[IMG]local://upfiles/13231/02DEE15084CD406195DB3F38F8A9101B.jpg[/IMG]
[IMG]local://upfiles/13231/B952DEB9B2F04F6DBA7D475ABC81BB4B.jpg[/IMG]
#26
I am hitting the dyno next saturday, dont have a baseline but just ordered these deletes...so i SHOULD have them installed before the dyno run...so i guess i wont know for sure either but my #'s should tell if they worked or not...
#27
remember finding a valve on the driver's side (only) exhaust manifold when I first took my 85 apart
Is is great for performance, no and usually they clog with carbon through the years. But if you are driving a carburated car in the winter, sometimes it is needed.
As far as the CM plates. I am still on the fence about them. Is the the throttle response down low any sharper??
Problem is. When inspection time rolls around what happens?? If the car passes the sniffer test without the plates, will it pass with the tune? And what says the CAI's are 50 states legal. And being you cannot run the plates without the tune, things get complicated.
The way the car is now, 15 minutes worth of work and I can bring it to ford, inspection, whatever and not have worries.
#30
I have not reinstalled them. However, it looks like they would go on simply. I am not sure, but I'm guessing that as long as you don't move the servo when you take off the stock parts then it should go back on with no adjustments.
Keep in mind I haven't researched this or tried it, it's just observations based on looking at the parts.
