Winter Storage
Will finally be taking delivery of my new GT/CS 2007 conv. soon, the down side to this... I will have to store it for the winter, not taking this baby in the snow, slush and tons of calcium. Any good advise on storing this new baby of mine?
Thanks,
Thanks,
inside or outside?
if outside, get one of those portable garages and put a tarp down on the floor and a cover for the car
now regardless if in or out doors
wash and wax the car, and fully detail the interior
fill the gas tank up and put in a stabilizer
change the oil
get a battery tender
buy some foam pads to park on, DO NOT use jack stands
change the oil
dont put it on stands cause it take the load off the suspension and in the spring it wont ride right, as use the factory rims and tires for storage. Foam pads are to park the car on so you dont get wear spots on the tires from sitting in the same spot.
Also put wire pads in the exhuast, wrap the air cleaner in tin foil so you dont get mice in there.
Put bbq bricks in a pan, on the floor to draw out moisture.
