QUESTION about loss of HP
RE: QUESTION about loss of HP
Ok since my performance will drop with my 20's would a set of UD's compensate for the loss?? I am getting a supercharger hopefully before the year is over so for now i just hope to make up loss with some small additions.
A better compensation would be an aluminum driveshaft and probably an easier install.
ORIGINAL: Fireguy28
ORIGINAL: Fireguy28
ORIGINAL: Fireguy28
Ok im a noob what is that??
ORIGINAL: nbk13nw
CMCV deletes.
CMCV deletes.
The Charge plates on your car. If you think about older carburated cars. Well the butterfly that opens when you hit the pedal. Same thing really, just internal on our cars. Both side of the intake have four butterflies on the CMCV plates. Even at WOT they are opened but still caiuse a little loss of flow and I would guess some tubulance. When removing these and replacing them with a set that do not have the flaps built in. The restriction is gone. It looks like the gains are anywhere from 5 to 10 HP / TQ dependnig upon the car. A cheap (Less than 100.00) and easy install.
Powerhouse 411 is one place to look. There are others. Looks like there may be some competitive pricing soon since others are starting to release them now.
So far no issues other than some sputtering above5800 rpm, this I think was due to running hard on a cold engine. It has not happened since that time. Otherwise, the MPG has stayed the same. The bottom end feels stronger, and the mid / upper rpm range is definitely stronger.
ORIGINAL: nbk13nw
Getting back on thread, since the CMCV is not the throttle body then what does it do? Are there linkages to these butterflies or are they spring loaded and rely on intake vacuum to open?
BB
