Gears!
Old Oct 14, 2006 | 03:23 PM
patrik10's Avatar
patrik10
Default RE: Gears!
Thank you guys. I think I'll go with the 4.10s.
Old Oct 14, 2006 | 04:08 PM
01RobGT's Avatar
01RobGT
Default RE: Gears!
4.10 is the only way to go...AVG 22 mpg on the highway with them in my 5spd
Old Oct 14, 2006 | 10:50 PM
MikeVistaBlue06's Avatar
MikeVistaBlue06
I ♥ Acer
Default RE: Gears!
ORIGINAL: mustangman02232
T3650 5th gear is .62
You keep saying OD is 0.62 on the T3650. The only spec. sheets I have seen for them show they are 0.68.
Did Ford change this? Where are you getting your specs from?
Thx,
Mike
Old Oct 15, 2006 | 11:10 PM
Tri C's Avatar
Tri C
Default RE: Gears!
.62 is correct according to Ford published specs I've seen.
Old Oct 19, 2006 | 06:37 PM
06stangGT's Avatar
06stangGT
Default RE: Gears!
ORIGINAL: MikeVistaBlue06
ORIGINAL: lynwood78
How's 4:10's for the auto? I'm really thinking about getting it.
Go 3.73's for an auto since it has an OD of 0.75. You will tach approximately 2500 @ 75 and 2000 at 60.
4.10's are a bit too much for an automatic, but are perfect for the manual which has an OD of 0.68.
With 3.73's in an auto and 4.10s in a manual, they are basically geared the same. Technically the automatic will have a slightly lower gear ratio, but it ain't that much:
Manual final drive ratio = 4.10 X 0.68 = 2.788
Automatic final drive ratio = 3.73 X 0.75 = 2.7975
As you can see, the automatic with 3.73's has a slightly lower gear (higher number) than the manual with 4.10s.
Mike
ORIGINAL: therobman7
i always thought stock was 3.27, is it really 3.55 stock?
05-06 5 speed 3.55
07+ 5 speed 3.31s
all s197 auots are 3.31
new edges were 3.27
so i just talked to my dad, he has an 07 GT 5 speed. I told him that he had 3.31's after reading that...and he said that He has 3.55's. He said hes almost 100% sure because he read it somewhere with all the specs on the 07+ Maybe he read this before they decided to put 3.31's in the 07's??? Any ideas?
Old Oct 19, 2006 | 06:47 PM
jlpskydive's Avatar
jlpskydive
Default RE: Gears!
The 3.55's are an option on the 07 5 speeds. Like 150.00 bucks extra.
Old Oct 20, 2006 | 12:30 AM
06stangGT's Avatar
06stangGT
Default RE: Gears!
ORIGINAL: jlpskydive
gotcha
Old Oct 20, 2006 | 03:27 AM
lynwood78's Avatar
lynwood78
Default RE: Gears!
Well I'm off to order my 4:10's
Old Oct 25, 2006 | 04:06 PM
red_fire_GT's Avatar
red_fire_GT
Default RE: Gears!
I have 4:10's on my 06 auto and love em. I don't do a bunch of highway driving but even on a couple of 150 -200 mile trips I didn't notice a huge drop in mileage. Around town the mileage drops some but that is probably due to my uncontrollable urge to hear my tires chirp when shifting to second with the hammer down
[IMG]local://upfiles/49451/8BDEB6F68EA14405B276328DB921A9A3.jpg[/IMG]
Old Oct 25, 2006 | 04:27 PM
06hoss's Avatar
06hoss
Default RE: Gears!
[[/quote]
05-06 5 speed 3.55
07+ 5 speed 3.31s
new edges were 3.27
[/quote]
Close... Only the 05-06 GT COUPE, 5 speed came with 3.55s. The 05-06 GT VERT, 5 speed came with the 3.31 just like the auto. The only way you could get the 3.55 in 05-06 was a GT, 5 speed, COUPE.
