Supercharger ???
Old Oct 18, 2006 | 01:48 AM
speeddemon's Avatar
speeddemon
Default Supercharger ???
I know this has been probably asked before, but please just bare with me fellas. I read that our 2005+ Mustang 4.6L V8 can handle outside modifications (CAI, headers, etc.) up to 425 hp, before the engine has to be modified internally (pistons,valves, etc.). My question is if I could put in a supercharger kit in a stock Stang GT engine and not change out any of the stock parts? If no... what do I change? If yes, what would you recommend to upgrade? I know bigger fuel injectors and an intercooler are a plus... Thanks guys!
Old Oct 18, 2006 | 02:28 AM
05gtdriver's Avatar
05gtdriver
Default RE: Supercharger ???
ORIGINAL: speeddemon
I think more like better quality head/con rod/main fasteners, forged internals(pistons/rods/crank) are needed for major boost levels. With most affordable S/C kits that are smog legal the boost levels aren't too ridiculous(usually under 9 psi) so with proper fuel delivery(upgraded pump/injectors) and a quality tune and good grade gasoline you shouldn't have to worry too much about internal engine work. Just need to make sure the engine is properly fed with enough fuel and has proper timing for the S/C you decide to use.
Old Oct 18, 2006 | 03:09 AM
05SDI's Avatar
05SDI
in short; Many of us are over 500 crank HP on stock block and other then bolt on items. (yes a supercharger is bolt on lol)
Some where over 550 crank HP you see HP related failures.
There are many routes to get you to the 500+ hp circle! None it completely head and shoulders abouve the rest to that level. The difference (to me) is where are you planing to go from that point? Price for a driveable 'installed' kit. Knowledge from tuners and forums like this one and others. Just because I went wih the Saleen doesn't mean it's the best S/C (or turbo) there is out there for every persons meeds/wants. I went with it because it'll take me further then I'm ready to go today and the price was right and install was almost straight forward. Good luck with your choice and keep an open mind before and after you decide on one!
05SDI
Old Oct 18, 2006 | 04:18 AM
Herknav's Avatar
Herknav
THE most important consideration in any power adder, (SC, Turbo, or NO2) is TUNING. Find a reputable tuner and go from there. Decide what you want, (low end torque, high end, etc) and find the best application for your desire.
Old Oct 18, 2006 | 01:39 PM
fordfanboy's Avatar
fordfanboy
I ♥ Acer
^^^+1
The tune is what is the culprit of 99% of windowed blocks on these cars. Not that you can go ridiculous on the stock bottom end but the 400-450 limit is a myth. There are many cars at 550 rwhp on the stock longblock with no problems and there are motors that let go at 400 rwhp. The difference in almost every case was the tune.
Old Oct 18, 2006 | 10:18 PM
carnut's Avatar
carnut
fordfanboy is right (listen to his advice he knows a TON) about how the engine can really hold like 500-550 at the crank. like he said its all about the tuner you get. with that said 450rwhp (about what youll be making with 500+ at the crank) is crazy. it makes the car completely different. most people can chirp the tires at like 50mph. just research what you want it for and how much your willing to spend because the more power, the more it costs.
Old Oct 18, 2006 | 10:22 PM
Wally39's Avatar
Wally39
I can chirp my tires at 50 mph. The very firm shifting from the tune helps with that. Plus the extra ponies
Old Oct 19, 2006 | 01:21 PM
speeddemon's Avatar
speeddemon
So what is a good tuner out there?!?! I'm assuming if I went with Magnacharger, procharger, or etc... they would recommend the best tuner for the SC. I got an 06 Mustang, so what's the best SC to get for an almost daily driver and being on the track every now and then? YOU GUYS F'IN RULE, THANKS FOR ALL THE HELP!!!
Old Oct 19, 2006 | 07:25 PM
RCT06GT's Avatar
RCT06GT
If I was going FI I would go with the Kenne Bell(2.6) or the Whipple supercharger. POSSIBLY even look into a Powerhouse turbo (kind of OT, my bad).
Old Oct 19, 2006 | 11:50 PM
carnut's Avatar
carnut
speeddemon - thats the thing. all those guys would tell you to use their tunes AND ONLY their tunes. nobody else. you need to find a shop that has worked on other FI mustangs and make your decision from there. as far as best supercharger for street, i personally would go with the saleen. its pretty cheap (around 5,100) and it makes good amounts of power from 4psi of boost (this is conservative considering these engines can hold 9-10 psi stock with good tune). honestly though its your money so you should make the final decision.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
