Hesitation Question. Need some help. PLEASE!!!
Ok I have noticed that when I am really testing my 06 GT.. when in second gear.. I'm at about 4 on the rpm driving normal as far as gunning it.. then.. I floor it.. I will get this small hesitation.. like it will pull me (usuall feeling when flooring) then back off for a sec .. then go in full again. Its just for a sec but I can feel it. This wont happen at low RPM... it happens at about 4 if I floor it.
My question is this.. I really don't think I have ever COMPLETELY floored the car at second AT THAT particular RPM rate..
Well I was wondering if this is normal.. I am completely stock.
I did get my rear end clutch pack replaced the other day because I had that moaning noise.
I was wondering if this could be something with the clutch pack not being broke in or perhaps not done correctly.. or if this is just normal when flooring at 4 rpm.
Can someone give me some advice on this? Thanks.
Oh also I notice when I do this that the traction light goes on.. even with tc on.
So maybe this is just the car losing traction and then gaining again that I am feeling?
RE: Hesitation Question. Need some help. PLEASE!!!
turn tc off and try it....mine only hesitates when i'm hot rodding it and stuff and it starts to break traction...if you turn tc off, you shouldn't have a problem
To me it sounds like the hesitation tsb that many of us have had done. Have you had that done yet?
Hesitation TSB
If you already had this done than I dont know what your problem could be. If you have not its a no charge correction from Ford.
Good luck
Hesitation TSB
Good luck
mungodrums
Suspension
09-24-2015 10:12 PM
