please help - superchager problem
Hi All,
I have the 2005, Mustang GT (Auto), D1SC Procharger Superchager with 800hp intercooler.
Running at rwhp.465 @ 9 psi
I’m having some BIG problems after installing the procharger.. first problem was the supercharger belt came off the crank pulley, we then changed and aligned the supercharger again (even though it already looked fine) we bought another belt off a local shop and it keeps snapping..?? The guy in my shop made a custom damper but that didn’t work.. it snapped again on the test drive..
He seems to think i need to order a special supercharger pulley damper to stop the belt from snapping or coming off again..? What do u guys think, I’m not mechanic so i know very little about this subject.. if this is the case do u know where i can buy this from?
ur help on this will be much appreciated.
Mark
Mark
ORIGINAL: Mark_Dubai_2005GT
Hi All,
Mark
Hi All,
Mark
Hi imyy4u and thanks for the feedback, Ithought it would be that from the start.. To be honest the guys who are installed the supercharger aren’t the smartest of people, Quite worrying really.. One question. - Do u think its necessary to buy the damper or not, the supercharger was custom made for this make, model, yr - car, surely if everything’s aligned perfectly there should be no need for the Pulley damper??
Cheers
Cheers
I have a friend who just had a Procharger installed and is having no problems with belt slippage , breaking or anything. Your right , it was engineered for that model car and there are lots running around without issues like that. I would think if the damper was needed, it would have been included. Best to put it the way it was built as that could possibly be another source of trouble IMHO. Another ex-member of our Wildhorses club here in Nashville had one (Procharger) on his 06 last summer and I don't remember any issues with his either. Those HP numbers are about what the ex-member had, however my friend had that same unit installed and is "only" putting out about 440 RWHP and 375 RW torque, he is a little disappointted. He also is having some trouble code lights that sre showing up now, but I think the car runs pretty good otherwise. At least your problem can be addressed with an belt alinement - electronic or ECM problems can be a real headach!
Good luck dude.
Good luck dude.
HI
After further examination to the supercharger we have worked out that the problem and the reason why the belt keeps slipping is because when I rev the car in red or go at high speed the pulley shakes from side to side causing the belt to come off. The guy a the shop said my car needs a new damper cos this is causing the belt to jump off. Do u think this is correct? i have seen it with my own eyes and i can see when the car is rev hard the pulley shakes quite alot.
Any advice? do i need a new damper custom for this supercharger? Any idea where i buy this from?
Cheers
Cheers
When you say "new dampner" I assume you mean belt tensioner? If so, there are several people having issue with the belt tensioners on these cars, depending on the FI solution they are running. Seems to be common with KB and Prochargers. The Whipples, Saleens, and Roush SCs don't have the issue ( that I have heard of yet ). Most of them are seeing the tensioners either bend or break, and it is happening on decel. Few different solutions being tried at the moment. Reinforcing the stock tensioners, installing tensioners from trucks, not sure if anyone has actually came up with a true "fix" yet though.
no problem so far with my Vortech...
[IMG]local://upfiles/50057/418C74CC7E7840FF8A6A37CB38327022.jpg[/IMG]
[IMG]local://upfiles/50057/FE5DB04CCF2D4A9D96F1082B5E17F681.jpg[/IMG]
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
