3V Crane Cams
Old Dec 5, 2006 | 10:48 PM
spdbrake's Avatar
spdbrake
Default 3V Crane Cams
I think this maybe too soon / new to ask if any one has found these instock yet.
All Stages 1-4 require Springs.
Stage 3&4 require higher compression.
Stage 2/3/4 require dished pistons OR removal of the Phazer timing retard OR Custom tune.
I wonder who the Custom tune Guinea Pig will be (Not Me)
http://www.cranecams.com/pdf/PP1105B.pdf
Geezzz look at the lift and durations.
Here are Crower numbers.
http://www.crower.com/cat/domestic/f...amshafts.shtml
And the Comp Cams.
http://compcams.com/information/what...eCamshafts.pdf
Old Dec 6, 2006 | 05:17 PM
ebr's Avatar
ebr
Default RE: 3V Crane Cams
Comp cams tells you the nessecary improvements needed.
Check RPMOUTLET.COM then go to Comp Cams 05 4.6 3v.
Also I just post wanting to know about prooven gains on these so watch that as well.
Old Dec 6, 2006 | 05:44 PM
CrazyAl's Avatar
CrazyAl
This is wrong information, at least for the Comp Cams.
None of them require dished pistons, changes in compression, or anything involving the Phasers.
They do, however, requrie springs.
Brenspeed has a writeup on the stage 3s. Visit their website then click the "Tech" link.
Several people on m o d u l a r f o r d s have them on their cars. There's at least one guy with stage 4s, and a few with stage 3s. None of them did anything other than swap cams and springs and then dyno-tuned.
Old Dec 6, 2006 | 06:45 PM
retfr8flyr's Avatar
retfr8flyr
If you look at the specs comparing the Crane grinds to the Comp Cams you can see where the Crane would require more mods than the Comp cams. Look at the lift on the 2,3,4 Crane cams, that much lift will most likely cause valve to piston clearance problems in a stock motor.
Earl
Old Dec 6, 2006 | 07:11 PM
CrazyAl's Avatar
CrazyAl
Sorry my post wasn't clear.
I was talking about the COMP CAMS. I edited it a bit, hopefully that will be less confusing.
You are right, the Crane are more extreme.
Old Dec 6, 2006 | 08:36 PM
classj's Avatar
classj
Crang cams has been having SEVERE quality problems over the past 5 years. I would stay away for sure. I had a two sets of bad mopar rockers that were a nightmare.
Old Dec 6, 2006 | 09:30 PM
spdbrake's Avatar
spdbrake
ORIGINAL: CrazyAl
I guess I wasn't clear either. My post subject is 3V Crane Cams. I was repeating only what Crane has in their Ad (Pistons, Compression etc...)
My point was / is that the Cranes are too radical in lift for me to consider using (I'm not doing a full rebuild, Dropping Phazers, Trusting a tune).
I threw the Comp and Crower in for everyone to compare.
I've looked at Brenspeed and bought some of his stuff to include tunes, he's a reputable person.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
