Advise on rear tires
Today I ordered the titanium CAI with the brenspeed tune the violater cat back and the steeda strut tower brace. My next move is to go 3.73 in the rear (AUTO) I wanted to go with an 18" rear tire set to get more rubber on the road. What do you guys think?[8D]
RE: Advise on rear tires
ORIGINAL: PROMETHEUS PRIME
I would stay with the 17's so you'll get more out of the gearing. ...
It depends on the tire size you put on.
Rubber is more important than diameter. Buy a set of drag radials. I recommend Nitto 555's as they are good street tires, great track tires and have a stiff enough sidewall to keep it sticky in the corners.
This will improve every facet of performance better than any change in wheel diameter will. Tires are everything
ORIGINAL: Stoenr
Not true. stock 17 diameter is 27" stock 18" diamter is 27" give or take a tenth. Gearing will equate to the same
+1
The only reason to go from 17" to 18" wheels is appearance. You can keep the same outside tire diameter on either wheel. Tires for the 18" wheel wil cost a little extra though. Either way, I recommend 275's on a 9" or 9.5" wide wheel. If you increase tire outside diameter, you'll have a teeny-tiny bit more road-contact area, but you have to have your speedo re-calibrated... and it will impact your choice of rear-end gears.
For traction purposes, more significant than tire size, is tire type. You need to switch to soft compound tires. However, all high-traction (soft compound) tires will put you down into the 10k miles range (or less depending on how you drive). I like the BFG KD-series tires better than Nitto's.
Beware, tire traction ratings (AA) are based on straight-line stopping distance on a wet road. In my case for example, I mostly want cornering g's on a dry surface. You also need to consider the road conditions where you're driving. Many racing tires are dangerous on wet roads.
All are good points I am going to look for a set of 17 inch wheels like I have for the rear but in a 9 inch width. I want to keep the side wall the same but would like more meat on the road. I have the 07 bullit rims with the silver powder coat and polished outer ring.
So anyone know what is the widest tire I can put on the back of my stock 18" polished aluminum wheels? I also would not like to decrease or increase the tire wall....stock is 235/50/18. Thanks in advance!!!
