hurst problems?
Old Jan 17, 2007 | 09:13 PM
acstone7's Avatar
acstone7
Default RE: hurst problems?
If your having some problems, double check your connections, and us plenty of locktite, I used a gel that seems to have worked real well after 3 weeks or so.
Old Jan 18, 2007 | 02:04 PM
06stangGT's Avatar
06stangGT
ORIGINAL: wjbiv
My research tells me that feeling a little driveline torqueing through the shifter is normal on these cars. The hurst does seem to transmit it more than the stock one.
Thanks for your input, i believe that is correct, also I will probably go back and use some locktite when i can get it up on a lift
Old Aug 21, 2008 | 06:40 AM
davisda1's Avatar
davisda1
Default Knocking
I don't know if it's always been this way or not, but I feel a knock when coasting and breaking. I have checked for loose bolts and used Loctite from the beginning. I can be driving and coming to a light and have my hand on the sifter and if everything isn't quite smooth enough I can feel a slight knocking when braking. Do you guys think this is torque from the tranny buckling up through the sifter, like your talking about.
Old Aug 21, 2008 | 02:51 PM
blackS197's Avatar
blackS197
hmm my hurst is really tight. Its real tight and hard to put in gear.
carid
Jul 8, 2016 09:55 AM
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Webster454
Sep 7, 2015 04:59 AM
