Crashed @ Track - Pictures
RE: Crashed @ Track - Pictures
So what happened? Some oil on the track perhaps? I read in another post that you did it after shifting into second. Were you power shifting?
I know I don't have as much hp as you, but i've never felt my *** end slide at the track shifting into second. That's no power shifting either.
how much Hp do you have at the wheels now?
hey nothsa, first of all sorry to hear about the accident and thank God you're not hurt, but is there any advice you would give to a racing newbie to avoid getting into a spill?
ORIGINAL: moosestang
The really bad part for him was that OSW just installed the Cement barriers over the holiday break, as its required for the 2007 events. So I bet he was the first person to tag the new wall. Hell he should have gotten out a marker and signed the wall where he hit it... If they still had the old metal gaurd rails in the damage probably would have been much less.
ORIGINAL: jay0heavenly
wondering the same thing...
Best advice is take the car while it is stock to the track. Lower teh pressure in the rear tires and turn off the traction control.
Its easier to learn and get a feel for the track when you have less power.
Which is why you don't get into a 500+ rwhp car and make you first pass at a track in it.
I highly recommend getting into drag radials or slicks for the track. Especially in the case I was in being stupid enough to go to a track that doesn't even prep their track for weeks maybe months depending if they have an even like vsop said.
That cement wall was very unforgiving,but with those old cheap side-rails there I probably would've just bounced off of it.
-Jeff
-Jeff
ORIGINAL: vsop
DR's will help, but you can run into wheel hop issue that will require some LCA's or an UCA to get rid of it
