Jack Stupid Question :)
Old Feb 6, 2007 | 11:58 PM
zubz's Avatar
zubz
Default RE: Jack Stupid Question :)
Don't trust jackstands? Never heard that one before.
Any of you that are working under your car w/ just a jack and no jackstands are out of your mind!
Old Feb 7, 2007 | 12:16 AM
Drop Top 06's Avatar
Drop Top 06
If you plan on working alone, the best option is to drop $20 grand on a hydraulic shop lift so you can stand under the car. Otherwise, stands or blocks work well. [sm=badbadbad.gif]
Old Feb 7, 2007 | 02:14 AM
RodeoFlyer's Avatar
RodeoFlyer
actually drop top - for those that don't know you can have a lift installed for about $2000
i use jackstands AND leave the jack under somewhere just in case. you can't put a price tag on safety. don't buy cheap - get quality stout-built stands
Old Feb 7, 2007 | 05:16 AM
therobman7's Avatar
therobman7
Screw the jack, I change my oil with the car sitting normal...
BUT, it is a pain, and I cna only do it because I got long arms. Anyone know some reliable brands for jacks/jack stands?
Old Feb 7, 2007 | 07:16 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I use the same and it is a 4 ton jack with jack stands at the frame rails or control arms
ORIGINAL: CrazyAl
A 3-ton floor jack (Craftsman) & I have several jacks stands, 3-ton and 8-ton sizes. I prefer the larger ones because they are more stable and the provide more height to work under.
Never work under a car supported by a jack only. Always block it up with proper cribbing or jackstands.
Old Feb 7, 2007 | 08:40 AM
howarmat's Avatar
howarmat
s197 Junkie
+1 to stands.....as said never trust just a jack to support the car if you are workingunderneath. You life isn't worth being to cheap to go and buy a set of jacks for 30-50 bucks!
Old Feb 7, 2007 | 03:05 PM
bonedaddyjr06's Avatar
bonedaddyjr06
go to autozone or orileys they still sell the car ramps....got two of em for like 35 bucks....nice to have around
Old Feb 7, 2007 | 03:21 PM
MyGrabberOrangeGT's Avatar
MyGrabberOrangeGT
make yourself a couple of drive ups with some 2x12's. Lifts the car 3 inches which is great for the oil change and also for swapping out the axle backs. I have four and the car is up on them for the winter. 3 inch lift all around.
Old Feb 7, 2007 | 03:23 PM
techmanBDsStang's Avatar
techmanBDsStang
ORIGINAL: bonedaddyjr06
Same here. Went to Kragen and got probably the same ones. They are a plastic material, and are rated for 8000lbs. Also have a big lip in the front, so you know you won't go over like I have done in the past with other types that didn't have a lip. And the angle to drive up isn't steep so I don't hit the lower part of the car. Then to be safe I have chocks I put behind the wheels that are on the ground.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
