STS Turbo Dual Exhaust
Don't think this has been asked, or if it has I'm not very good at searching for it... but:
I'm looking at the single turbo STS system and I'm wondering how that works with dual exhaust. I know the turbo attaches on the one side, but what of the other one?
Any information would be great!
RE: STS Turbo Dual Exhaust
it should come with a header with two outlets, one of which the turbine connects to, and one that retains the factory h-pipe, or any other fitting pipes. it comes with an electronic boost controller that you can set at a certain psi at which the wastegate opens and releases the extra air into the pipe.
and for ur fyi, i dont know if ur interested, but granatelli and turbocharged power are making a twin turbo sytem for the s197..it uses two small turbos that can make as much or more boost than a large turbo, and reach the max boost at lower RPM's than the STS big single turbo, which means less lag...not sure how much it is but twins are better than 1
ORIGINAL: 07GTgo
the other side is just a regular header
wtf? are u sure? how can that be?
one cylinder bank poowering a turbo, the other a normal exhaust? that sounds....well, it just doesn't sound right to me
What? No...this is what it looks like.
[IMG]local://upfiles/21520/364DE19F698447E2997FE702B1A3A082.jpg[/IMG]
ORIGINAL: 07GTgo
ORIGINAL: pj1010
ORIGINAL: 07GTgo
This particular configuration makes self installation much much easier.
ORIGINAL: AmericanMuscle4.6GT
that looks so incredibly weird/awkward. a little turbo in the corner.
ORIGINAL: pj1010
ORIGINAL: 07GTgo
