Aftermarket clutches rattle?
My factory clutch has always rattled when letting the pedal out with very little accelerator applied. It also rattles some in neutral, but not nearly has loud as when it's engaging.
For those with aftermarket clutches like spec, did this rattle get worse, the same or better = less?
RE: Aftermarket clutches rattle?
Never heard a rattle from my GT. I have an 03 V6 and the clutch rattles quite a bit. I heard that was a problem with that year. You may have a bearing problem. If still under warranty, take it back.
ORIGINAL: owero01
I'll just change my clutch to a spec stage 2 and replace the bearing.
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
