Alignment issues???
Old Mar 14, 2007 | 07:57 PM
Zellanor's Avatar
Zellanor
Default Alignment issues???
Just installed my Wheels and tires. When I get up tp 45mph and beyaond theres vibrating in the steering wheel. It doesn't pull to any side, just vibrates. Thanks for the info
Old Mar 14, 2007 | 08:13 PM
22kart22's Avatar
22kart22
Default RE: Alignment issues???
sounds like toe issue to me. Also, definately get an alignment because you dont want to wear out those babies...
oh and also maybe the tires arent properly balenced
Old Mar 14, 2007 | 09:13 PM
owero01's Avatar
owero01
Balancing. If it continues, have the dealer you bought them from check to see if one of them is out of round.
Old Mar 14, 2007 | 09:39 PM
Feng Houzi's Avatar
Feng Houzi
blinker fluid?
Old Mar 15, 2007 | 02:46 AM
offrdmania's Avatar
offrdmania
Time for a basic lesson in alignment. First off, a tire shake is never caused by alignment. Shake in the steering wheel is most likely from a front tire being out of balance. Hopefully it isnt from loose lugnuts, check that as well. The only way to check that the alignment is out is tire wear or a pull. Usually a pull is from the caster being out, caster is a non tire wearing adjustment and the caster adjustment on a mustang is very little. you will most likely get a pull from a mustang the wider of tire you put on. Second and third are toe and camber. These usually show wear on the inside and outside shoulders of the tread on a tire. You usually cant feel these adjustments being out.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
