Did you have to remove your mid-pipes to install your drive shaft?I'm going to have the rear end completely out when I do my suspension mods.I was hoping this would give me enough room to install my drive shaft without having to removethe pipes out too.
Damn 30 minutes with a lift maybe! Moosestang stated 3-4 hours which is probably about how long its going to take me.
Well if you use my post as a guide it shouldn't take more than 1 hour. Remember I spent atleast 30 minutes going to the autoparts store to get the hex bit and then I didn't realize the trans bolts were a 12 point socket, don't see to many bolts like that and I thought Ford made up another special tool.
It will take you 3-4 hours to install that adj. upper control arm that you're going to need.
