Next Mod Suggestions
Outside of whats in my sig, I've got CMCV plates sitting in the garage and a BMR rear sway bar waitig to be installed.
I've also done the billett thing in the interior - cup holde bezel, AC *****, e brake handle, power point plug...also got a shorty antenna.
Outside of LT's, Cams or a doing a SC what should I do next? Preferrablyy go fast mods....
I don't want to lower the car because my drive way is steep and will scrape exhaust / facia if I lower it....
RE: Next Mod Suggestions
Not sure why you don't want LT's, but you could finish up the suspension...I see you still have no UCA, could get the LCA reloc brackets and maybe just get some Roush rear springs (if anything that will bring the nose up a tad and improve stance) and put on some Tokico D-specs....that should take care of you for suspension and handling (for the most part)....the DS is also a good idea, and while you are at it you always go with a aluminum flywheel and new clutch....you didn't mention no spray!!!!...raptor shift light....electric wate pump....A/C delete....i'm starting to run thin here.....some fat tires....yeah i don't got much else for you.....oh yeah.....a search button...those help too
I want LT's they justseem like ahigh costrelative to thepayoff. Looking at $50 p/ hp or p / ft lb or torque. That's assuming I gain 20hp / 20 ft lbs and they cost $1K....
Well I'm a new Mustang owner....my first one ever and I dont know too much about cars...never worked on one. I read your description of your mods and I dont understand any of it except the part about the window tint. Other than that, I might as well be reading Spanish. The Shaker hood you see on my car was already on there when I bought it.....yea it's a used car. I have no idea what it does. What I do know is that stripe down the middle of my hood is not paint and it makes the car look cheap....wish I could change that.
I'd like to know what all these "mods" cost and what they do for my car...weather its cosmetic or improves how the car runs.
ORIGINAL: Chevy Convert
I am trying to get this question answered in another thread but no luck. Can the CMCV plates be tuned through a hand held SCT tuner?
I would go for the exhaust. The longtube headers and the mid pipe (x pipe or h pipe) will make such a difference in performance and sound. It will also add a lotta hp. I also agree with MexGTand owero01. A new torque converter would help the launch and prevent the tranny from just dying when you do supercharger the car.
ORIGINAL: tonkpils555666sas
The "search" button will set you free....
