Valve cover torque specs
Old 05-04-2007, 04:12 PM
Zellanor
Zellanor's Avatar
Default Valve cover torque specs
All
I am getting ready to paint my valve covers and was just curious to what the torque specs are? also, will I have to buy new gaskets? Thanks alot
Zellanor is offline
Old 05-04-2007, 04:48 PM
partsbill
partsbill's Avatar
Default RE: Valve cover torque specs
89lb-in
alternating from the center out, top to bottom
partsbill is offline
Old 05-04-2007, 05:11 PM
Drop Top 06
Drop Top 06's Avatar
When I contacted Steeda, they said something like 35-40 ft pounds... I haven't done this yet as I haven't received the same answer from two sources...
Drop Top 06 is offline
Old 05-04-2007, 06:59 PM
jrm1900
jrm1900's Avatar
ORIGINAL: partsbill
89lb-in
That is the corect answer according to Ford Service manuals.
I forgot, I read a post in this forums saying you can use the same gaskets a long as you are careful when removing and reinstalling.
jrm1900 is offline
Old 05-04-2007, 07:03 PM
jrm1900
jrm1900's Avatar
ORIGINAL: Drop Top 06
Be advised if you intend to order the blue valve covers from Steeda that the color they advertise as blue is totally misleading, the blue color is justone shade shy of being absolute black, I learned the hard way.
jrm1900 is offline
Old 05-04-2007, 07:58 PM
Zellanor
Zellanor's Avatar
Thanks alot for all the info, I will post pics when done.
Zellanor is offline
Old 05-05-2007, 03:10 AM
Lees07GT
Lees07GT's Avatar
You would never want to torque valve covers 35-40 ft-lbs. That is a LOT of torque. 89 in-lbs sounds much more reasonable.
Lees07GT is offline
Old 05-05-2007, 03:16 AM
Drop Top 06
Are there torque wrenches designed for lbs-in? I've only seen ones in ft-lbs
Old 05-05-2007, 04:16 AM
Lees07GT
Lees07GT's Avatar
Some smaller torque wrenches are graduated in in-lbs. But you can use a ft-lb wrench for an in-lb spec. Just divide the in-lbs, such as 89, by 12. This gives you approximately 7.5 ft-lbs.
Lees07GT is offline
Old 05-05-2007, 04:31 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Yet another lesson on torque specs! Thanks
mygt500 is offline
Quick Reply: Valve cover torque specs
