MEZIERE ELECTRIC WATER PUMP
RE: MEZIERE ELECTRIC WATER PUMP
I know lots of guys that have these pumps installed on their Marauders' 32 valve engines and they all speak very highly of them. Haven't heard of one failing yet. FWIW.
ORIGINAL: Fourth Horseman
Hi FH,
My Meziere eH2O pump made a noise so I descibed it to Meziere and they sent me a new pumpwhich did not make the noise. The pump never actually failed as it was new and pumping coolant fine, I just was uncomforatble with the odd noise it made. But no matter it was taken care of by Meziere no problem.
Cheers/Chip
they also dont cavitate at high rpm.
Androdz - did your Mustang come with at least a dummy tempgauge? I'm pretty sure they all doThat would give me an indication of a water pump failing
ORIGINAL: fordfanboy
I didn't get a PM from you??
I understand the no warning if the pump fails and having a monitor for E pump is a good idea. I was commenting specifically how you said 'IF THE BELT BREAKS' - you're post wasn't talking about just the pump failing, but specifically that if you tossed a belt, you wouldn't know it with the EH20 pump and that's why I said, 'LOL' cause if you toss a belt, you'll know it real quick regardless of what type of water pump you have.
Andrew
ORIGINAL: RodeoFlyer
Andrew
ORIGINAL: androdz
Ah ok I guess I was rather ambiguous because I already lost an engine due to an electronic water pump failing and not breaking the belt no warning until it was 2 late.
Andrew
Andrew
My point is the 'dummy' gauges are just that - dummy gauges - it really doesn't show you anything until it may be too late.
Hey Androz,
Don't you have a water temperature gauge? There is agauge in my '05 GTand it works just fine, it shows water temp rising and falling and if the temp gets too high I also get a light on the dash.
Cheers/Chip
ORIGINAL: F1Fan
Hey Androz,
Cheers/Chip
Hey Androz,
Cheers/Chip
Andrew
Hey All,
While I've not had a water pump failure on the S197 in my experience when a car is overheating you get plenty of warning signs. Usually the coolant would have to get pretty hot for the light to go on and in the mean time the gauge would be reading higher and higher. The other tip off is normally the steam and water pouringup out of the hood and smearing your windshield. If your pump failed and you didn't notice the lights and gauges warningyou it would normally still take some time for the coolant to heat up to the boilover point and for you to loose enough coolant to damage your engine. The engine must have been runing very poorly by then and you should have noticed it. The only possible way for the pump to have failed and your engine to overheat and cause engine damage would be if your engine had been overheating for a long period of time prior to the electric water pump failing. Then the coolant levlemight be marginal enough for you to not get a warning light or a high guage reading. But if that were true then the pump did not fail and cause the overheating it would have to be the reverse, the lack of water would have caused the pump to seize and your already damaged engine was the cause. This sounds more like a case of poor maintainence and inattention to your gauges and idot lightsthen any fault of the electric water pump. But sometimes the obvious is not so obvious at the time I suppose.
Cheers/Chip
ORIGINAL: F1Fan
Hey All,
Cheers/Chip
Hey All,
Cheers/Chip
Andrew
