1\4 mile times
RE: 1\4 mile times
You should be able to stay in third, so do that. And like the others said, do some tire pressure changes, work on your launch, and youll drop a few tenths. You did good not burning your tires and not hitting the water box. These are street tires and they dont gain any traction from being warmed up, in fact its the opposite. Just do a little spin to get some dust off, but dont get them heated.
RE: 1\4 mile times
ORIGINAL: 05gtgreen
It was launching not to bad, spun a little but once it stopped spinning it would bog down to low rpm's then go. I left it in third through the quater mile, reving at like 6300rpm, should have I shifted to 4th? Also what tire pressure do you recommend with these tires, should I go less then 28psi, and I never did a burn out with them, I went around the water and spun them to the line to clean them off. see how it does next weekend, lol.
RE: 1\4 mile times
The reason the car bogged down was because you shifted while the wheels were spinning. Getting wheel spin under control is going to require some suspension, tires, and practice.
If you're running on stock tires, fill the front to about 40 psi, and drop the rears to around 25 psi. I've got the 17" Brushed Aluminum with the Pzeros; so different pressures may work for different combinations. (IE the 18" with the BFG.) Nevertheless, just keep messing around with the pressures under you're confident you found something you like.
Lower control arms, with the relocation brackets are probably a must, and will definately help keep the rear end stable and on the ground. (Instead of wheel hopping.)
Hope it helps. All I'm running is a C&L Intake, 93 Octane Brenspeed tune, Steeda UDPs with LCAs (No relocation brackets) and a Steeda Tri-ax, on 1/4 tank unleaded (just happened to have that much when I went). I don't think the Tri-ax contributed to my times at all, I ran a 13.104 without the tri-ax. It just makes my shifting more comfortable (it sits higher, and of course the shorter throw.) Anyway, my best time now is a 13.075 @ nearly 108 mph. My 60's are only in the 2.0xx range. Relocation brackets should help me break into the 1.9xx.
RE: 1\4 mile times
I am running Nitto 555 255\50 17's on the rear. I only spun the tires a little off the line, but enough to make a ****ty 60 foot time. I just need to learn how to launch the car. I will pump the front tires up next time. think I am goin again this friday.
inyadreems
08-21-2015 09:10 AM
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
