Motion Control Plates?
Yes and no. They both yield the same HP numbers. The $300 version is CNC machined and have slightly bigger openings than the frrp/econo plates. With that said 99% of the threads you read about delete plates are talking about the "econo" version which works just fine. Hopefully that answered your Q's.
ORIGINAL: MexGT
Has any1 tried just to take off the valves of the stock motion plates ? Will it work ? or they can´t be taken out?
I've noticed alot of the S/C guys that havent "deleted" the butterflys, wouldnt this be a big benefit for a S/C setup?? Afterall, you are trying to cram all the air you can into the engine.
It makes me wonder if they're actually that restrictive.
Just a thought, I'll admit I'm a little confused by these things.
Justin Burcham blew a motor when the butterflys stuck and he sent 16 psi through a single cylinder...[sm=badbadbad.gif]
It is a very wise mod to have with FI. Most kits delete them anyway. Centri's and turbos should do it on their own.
They are supposed to be open at WOT so with FI it really isn't a matter of getting more airflow - it's matter of eliminating the chance for them to stick.
