CEL Help!
Old Jun 15, 2007 | 06:54 PM
swensicle's Avatar
swensicle
Default CEL Help!
Well, over the last few days my car had been idling rough and the motor seems "unbalanced" like a vibration around 1k rpm's. I was running the b ama 92 torque tune and so I switched to a fresh 92 performance tune. NO DIFFERENCE. Decided i'd throw the old intake back on and run the stock tune only to get a CEL. I looked it up with my SCT and it was P0301 which is a "misfire detected".
I called the dealership and they can't get me in until next week. Does anyone have any idea what would cause this? Thanks!
Old Jun 15, 2007 | 06:59 PM
hammeron's Avatar
hammeron
Default RE: CEL Help!
if it were mine, i'd probably
disconnect neg bat cable
pull the plugs, inspect, clean if necessary, reinstall
reseat all of the coil over plugs
reconnect neg bat cable
drive the car and see if the problem persists
do this only if your comfortable with it
Old Jun 15, 2007 | 07:07 PM
swensicle's Avatar
swensicle
Thanks hammeron. I'm comfortable doing that, but the car is under warranty.....as long as they don't find out I had a CAI on it.....so I have an appt. to bring it in on Monday. The service guy said it could just be a bad tank of fuel or a plugged injector or something. He also said it was probably just a misfire....which is correct.
Does anyone else have any ideas what it could be besides an injector?
Old Jun 15, 2007 | 07:36 PM
modular81's Avatar
modular81
ORIGINAL: swensicle
It seems that your problem isn't cai/tune related since it came right back with the stock intake and stock tune installed. This is something the dealer can figure out. Probably a bad spark plug, coil, or fuel injector.
bryan616fl
Jan 25, 2019 09:07 PM
Urambo Tauro
Jun 10, 2016 03:28 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
BlackShelbyGt500
Aug 10, 2015 11:50 AM
