3.73 gears?
3.73 gears?
I was thinking about getting some 3.73 gears for my 07 Stang GT. Suggestions on who to buy it from? I know ppl say to stay away from ebay sellers, is this true. Also, if im driving on highway alot, would 3.73 gears be the best, or something around 3.55 or 3.31? any help would be appreciated.
07 GT
K&N CAI
Flowmaster cat back
Fuego flash tuner
07 GT
K&N CAI
Flowmaster cat back
Fuego flash tuner
RE: 3.73 gears?
With these gears, unless you unload on the pedal, your going to burn gas correct. but if your crusing, it really doesn't matter im guessing. What's the major difference in performance with the 4.10s 4.30's. where do you rec getting them. sorry im not that good with the linguo, but whats FI?
RE: 3.73 gears?
FI is forced induction i assume....such as superchargers and turbo's....i have a Q. tho if u dont mined me interupting ur post....is it bad to get 4.10's or3.90'swithFI.....would 3.73's be the best for a turbo(thats what im leaning towards right now)
RE: 3.73 gears?
Savanah07
First off are you an auto or a stick....if you are an auto you have 3.31 if you are a stick you have the same unless you paid $100 for the 3.55 upgrade. Check your window sticker to be sure.
next go here:
http://forums.bradbarnett.net/showthread.php?t=67040
Then find a good place to have install done. Check how many s197 they have done the install on or ford 8.8s also. You should expect to pay 300-500 for install.
Jegs or Summit would be the next place to look for the gears. Make sure they are FRPP gears and not motive....it is explained in the thread above.
next go here:
RE: 3.73 gears?
ORIGINAL: nhvickery
i have 4.10 and am going to need to buy new gears once again (f*ck)
RE: 3.73 gears?
Go climb under the rear end of your car and look at the pumkin, there will be a white sticker down there and that will be what you got in there. Mine is 3.31. Also unless your sticker reads you paid $100 for 3.55 limited slip you probably have the 3.31. For an 07 anyway
