WHICH ONE PIECE DRIVE SHAFT...?
RE: WHICH ONE PIECE DRIVE SHAFT...?
I first tested it my auto to make sure it worked cause many of the others won't work on autos. i doubt you'll need to adjust anything but i always make a point to let everyone know thats it's a possibility. i've only run into that 3 times so farand all 3 cars were lowered 1.5"+ the other 100 or so were all fine.
mexgt yours is ready along with 5 others and just waiting for Ford to send me the hardware. it should be here tomorrow so i'll get it shipped once the stuff gets here.
sorry for the delay having a holiday in the middle of the week messed up the deliveries so everyting will be back on track in a few days.
ORIGINAL: spyder7724
I tested all this stuff on mine since i have the coilovers and can adjust the ride height easily. I didn't mess with anything until i got to about a 2" drop. at that point the UCA flexed too much and things started to rub but once i swapped in a good UCA (it was even a non-adjustable at the time) it cured the problem. i never had any vibration problems at all no matter what i did to the pinion angle or ride height but it is a possibility cause these cars are so finicky especially the autos.
should be fine. is your UCA stock? if so you will notice a huge difference in traction/launch with an aftermarket UCA even a non adjustable. the stock bushings are so spongy they allow the rear end housing to rrotate a couple degrees during launch. thats what my traction bars prevent. i should have them ready soon. i know i keep saying that but it takes forever to get some of the components fabbed up and shipped out to me.
