Weight reduction
Old Jul 10, 2007 | 07:19 PM
saud alzaabi's Avatar
saud alzaabi
Default Weight reduction
U know I have it as a daily driver.. but what is the possible things I can do to a weight reduction ?
something like
bucket seats (looks nice leather but are lighter than stock )
K-member+A-arms from BMR
Lighter rims ( what are the lightest rims for a dialy driver on this planet? and how much are they ? )
I cant do a seat delete because sometimes I have to take those extra passengers :P
I was thinking about carbon fiber body panels like hood,fenders,trunk,bumpers....etc but thats too expensive.. I dont mind paying 3300 on all of them but more than that is too much..
Old Jul 10, 2007 | 07:37 PM
mills281e's Avatar
mills281e
Default RE: Weight reduction
Aluminum driveshaft if you don't already have one.
Old Jul 10, 2007 | 08:02 PM
howarmat's Avatar
howarmat
s197 Junkie
jack, spare tire.....the seat can be removed in a matter of minutes so the rear seat delete can be used pretty easily. spoiler delete, shorty antenna...
Old Jul 10, 2007 | 08:22 PM
damquick1's Avatar
damquick1
http://cgi.ebay.com/ebaymotors/Proch...spagenameZWDVW
With this weight would no longer be an issue!
Old Jul 10, 2007 | 08:40 PM
owero01's Avatar
owero01
LCAs will help.Do you have a CAI & tune? That will help increase your mpg as well as increase performance.
Old Jul 10, 2007 | 08:44 PM
explict's Avatar
explict
ORIGINAL: howarmat
haha
Old Jul 10, 2007 | 09:33 PM
s2k's Avatar
s2k
ORIGINAL: damquick1
Idk it could just be me but that kit looks really incomplete!
Old Jul 10, 2007 | 09:46 PM
howarmat's Avatar
howarmat
s197 Junkie
No feedback either....i would be skeptical
Old Jul 10, 2007 | 10:46 PM
zarins04stang's Avatar
zarins04stang
take the engine out, it will reduce a lot of weight
Old Jul 10, 2007 | 11:02 PM
RodeoFlyer's Avatar
RodeoFlyer
It's not just about removing weight. Removing rotating and unsprung weight will pay off MUCH MUCH more than just static weight. Try some of these things (not necessarily all rotating/unsprung weight)
1. lightweight battery - or move your to the trunk for better balance. the added cable will actually add weight but it's worth it.
2. lightweight driveshaft - the best mod there is weight-wise
3. aluminum flywheel - less strain on your motor, more power to the ground
4. Wheels - 5Zigen Fn01R-c, Enkei RPF-1 - these are both @ 18lbs in a 17x9
5. 2 piece rotors - costly but worthwhile on a street car. I would trash them on a road course too quick to make them worth the cost (@$600)
6. lightweight seats - try 50resto.com (that's 5-zero) Corbeau has some light ones and rails to go with them for CHEAP
7. hoods aren't much lighter than our stock aluminum ones
8. drain the washer fluid reservoir - hey....water weighs 8lbs per gallon. remove the whole system and throw a squeegy and windex in the trunk
9. mufflers - straight thru's like SLP loudmouths are much lighter than traditional chambered/turbo types
10. off road h or x pipe - don't remember what the cats weigh - but it's a bit
11.replace front hydro-bushings with Steeda race bushings. the hydro-bushings are like 5lbs a piece.
add it up - that's a couple hundred lbs off the car. start counting OUNCES
