Cams
Cams
Ok, like in the previous mustangs, if you change cams how high can you go and does the pistons have to be relieved for valve clearance? IE....
http://www.rpmoutlet.com/05gtknn.htm
RE: Cams
There have been countless, hour long debates about cams in the new 3v engines...The thing is, Ford did their research with the cams in this engine. The $1,000+ you will be spending wont get you more than 20rwhp. Dont get me wrong, thats not bad numbers, but its a lot of money. Keep in mind, most who have added aftermarket cams to their new 3V's, have lost torque...Its almost worth buying them for that cam idle though haha
RE: Cams
Modular Mustang Racing (MMR)will custom grind you a set of cams for you specific application that will outperform the others.Check 'em out.
www.modularmustangracing.com
