whipple problems
the instructions say to remove the hood liner. That's odd that it would break the belts like that. I wonder if they are making it too tight? It has a slider pulley that you can adjust.
Here's the instructions for installing the belt.
[ol][*]Install the supplied 6-rib belt. With the spring loaded tensioner in its max open position, adjust the sliding idler down as far as possible. Torque this bolt to 35 ft/lbs. (3/4" socket) and then release the spring loaded tensioner. [/ol]
Now i'm no professional mechanic, but either you have to much tension on the belt or your belts are defective. If it were an alignment problem you should see some signs of belt shreading/fraying. by your description it sounds like it's just snapping clean. If it were me i'd back that slider pulley off a little and tighten it to spec, this might cause some slippage under boost though.
This is either an alignment problem, atension problem, or an alternator bolt problem. Assuming all your bearings are spinning free, nothing else will cause this. Use a 2-4 ft level and or a plumb bob to check alignment. For tension, sometimes the stop on the tensioner must be ground off to allow enough travel. Lastly, make sure the belt is nowhere near contact with any of the bolts in it's path, esp. the alt. bolts.
ORIGINAL: drbobvs
Post a picture of the belt.
it happens man. I've broken about 7-10 belts with my blower system.
Use GATES belts or supplied Whipple Belts (as long as they arent gatorbacks)
tell them to put the pulley on that squeeled (sp). add some WD-40...if it goes away order a new belt and DIY.
Yeah, but this guys only running a 6psi pulley, he shouldn't be breaking belts like that.
ORIGINAL: TRYMY4.0
well after it snapped after the first week they installed a larger idler pully off of the h.o. kit whipple said it was better for the belt...but like i sais.. it squealed like crazy and i drove it three weeks like that cuz they said the squealing would stop but it didnt..... this was the longest i drove without snapping a belt....so i dont think it is an alignment issue but i could be wrong and i didnt get any picks of the belt, cj's took pics of it and sent them to whipple both times and both belts were directly from whipple they are made by DAYCO speacially for these kits, or thats what whipple told cj's
A couple of people on this forum have had similiar issues with the Saleen SC and they went back to the stock idler pulley and tension pulley plus this pulley from ford for the water pump F7UZ-8509-AA I don't know if it will fix your problem but for $23 it may be worth trying.
i havent heard of anyone running the h.o. kit throwing belts...... so they should just upgrade me haha or at least give me a good deal on the upgrade
that might fix my problem
