motoblue UDP's
so i bought some motoblue UDPs from rpm outlet, anyone else got these? The idler pulley was jammed inside the crankshaft pulley, and i should be able to tap it out with a hammer and punch(not the point end obviously). So who has these? Good/bad?
ORIGINAL: nate2953
there is definetly 3 pulleys, crank, WP, and an idler pulley
Replace your factory hi drag, low quality stamped steel OEM idler pulleys with the MOTOBLUEâ„¢ GEN X double bearing cnc machined billet aluminum idler pulley.
The MOTOBLUEâ„¢ GEN X 90 MM double bearing has been designed specifically to eliminate high RPM wobble common to auxiliary idler pulleys on supercharged applications.
The MOTOBLUEâ„¢ GEN X 90 MM double bearing effectively eliminates any bearing failure caused by supercharger belt side load. This is the same technology that industrial supercharger manufactures use for high load supercharged belt driven systems.
Installation does not require any modification, Hardware and detailed instructions included for a trouble free installation. These pulleys are in stock and available for same day shipping.
No offense but I have heard nothing good about rpmoutlet except their prices. If you are not happy and don't want to jack up the pullies send them back ASAP and check lmperformance. They are in florida and I am in NorCal, I order a Hurst short throw, steeda CAI, and Specs 2+ clutch and flywheel combo adn they were the only people besides my tuner that knew that the spec's clutch adn flywheel combo had to be balanced assembled or they would chatter. I had all my my stuff here with a week even the clutch/flywheel, plus if you call them and ask for a discount like I did you may get one.
