Buzz Buzz Buzz goes the S197
Ooookay. I've already had a thread on the vibration at a certain RPM - got it narrowed down to a midpipe issue. Gonna look at it next time I have it on a lift.
Anyway, does anyone else have it where the shifter/trans kinda buzzes at lower rpms..?
I mean, if I grab the shifter, it kinda stops. But if I let go while accel, it will buzz. Maybe it's the shifter naturally vibrating, but then causing the plastic around it like in the center console to buzz?
Any ideas?
Any ideas?
RE: Buzz Buzz Buzz goes the S197
Its definatly the boot. I have the same noise. It only happens when the stick is in one of the foward positions. (3rd and 5th). If you listen closely it sounds like a friction noise. Almost like the material is rubbing agaisnt itself when its folded up and crunched together. I had a buddy listen for it and he found it...and then I went ahead and grabbed the material around the shifted when the noise would start and it would stop. I tried treating the material with a leather conditioner to no avail. For one I dont even know if it's made of leather. I thought if I could soften the material it wouldnt squeek. Im almost certain its the material...
