New Turbo
New Turbo
Well I finally made the leap. I read waaaaay too much and had the roughest time deciding. But here's what I got:
Hellion Turbo system
GT500 fuel system
single aluminum drive shaft
new rotating assembly
SPEC stage 3 clutch and alum. flywheel
39lb fuel injectors
Cobalt autometer boost/wideband O2/pyrometer gauges
oh yeah and upped the coverages on my auto insurance!!!
Brenspeed is going to be installing it at the end of Sep when I make my trip there from CT. Apparently the shops I've taken my car to really have no clue how to tune the S197 stangs. And I really do not want to run a canned tune.
Oh yeah...how can I crop a photo so that I can finally post it in my signature?!?!!?
[IMG]local://upfiles/72546/1B22AF0C167346A68C175963D8451F26.jpg[/IMG]
GT500 fuel system
39lb fuel injectors
RE: New Turbo
Can you add any more mods with a turbo? I really want to do a turbo set-up. It seems to be the cheaper way to go. With a blower, one can still add lt headers and other bolt ons, but are these necessary or even possible with a turbo set-up?
RE: New Turbo
ORIGINAL: bmk
ah sweet man. what was your total cost for all that? the same amount for a 2nd mustang?
Turbo Kit 4995.95 (blowbyracing)
Fuel upgrade 749.95(lethalperformance)
Eagle rotating assembly 1995.95 (blowbyracing)
Drive shaft 755.00 (blowbyracing)
Spec Stage3 clutch kit 295.00 (got it off an Eleanor look-a-like from a local dyno shop)
Price for watching WRX/STIs, S2000s and camaros disapearing in my rearview mirror? FRIGGIN PRICELESS!!!!!!
There isn't much you can do as for bolt ons with a turbo system and I went with this system because it is safe and you can adjust the boost according to how you drive. I'm starting out with 8lbs then I'll gradually step it up. And then back down just for driving it around. Most FI inductions systems I found were said to create a HUGE amount of heat under the hood and with Supercharged systems its REAL hard to adjust boost to your needs. There is SOOO frigin much you have to do to the engine to make it safe. With my Strut brace I just can't fit a twin-screw blower...and centrifical blowers just are waaaaay too slow on the boost, plus they peg out real early in the RPMs. So this was the best bet for what I wanted. Power straight as soon as I hit the gas, low heat producing, easy boost adjustments from INSIDE the car on the fly! Even if I hadn't swapped out the rotating assembly I could have run between 5-9psi of boost safe on a stock cast block/internals. But I wanted more. And if I feel the need, with my set up I can swap to a bigger Turbo and get (eventually) almost 800RWHP. Just need a bigger blow-off and waste-gate valve.
RE: New Turbo
7-9 psi with the hellion kit and 9 is pushing it. Oh and get a turbo timer for your car and never shut the car down after beating on it.
RE: New Turbo
ORIGINAL: jdback19
