12v Switched Source?
Old Sep 18, 2007 | 10:40 PM
MacGyverGTP's Avatar
MacGyverGTP
Default 12v Switched Source?
I recently bought an Autometer Electric Vac/Boost Gauge (with memory) it requires a 12v Switched source that does not turn off while the starter is cranking...
I have no idea where to begin to look for this... I was thinking of just using a switch on a line direct to the battery as a last resort.
I had a Cyberdyne boost gauge that used a 12v switched source that turns off while turning the starter.
I replaced that cyberdyne 3 times because the LED's would flicker or burn out... I don't think they were made for Arizona heat.
Any ideas?
Old Sep 18, 2007 | 11:32 PM
tsquare's Avatar
tsquare
Default RE: 12v Switched Source?
If you mean a circuit that turns on and off with the key but still runs while cranking the starter, what about the fuel pump circuit?
Cliff
Old Sep 19, 2007 | 01:16 AM
MacGyverGTP
Great idea, but where can I locate the wire to splice into? Was hoping for one under the dash somewhere.
Old Sep 19, 2007 | 03:59 AM
moosestang's Avatar
moosestang
How about the instrument cluster power wire, does that turn off? I spliced into that for the light to my autometer gauge. It's black with a pink stripe and is in the wire bundle that leads up towards the steering wheel.
It says hot in run or start in my haynes manual.
Old Sep 19, 2007 | 07:23 PM
MacGyverGTP
Thanks! That one works...!
Much appreciated!
Old Sep 20, 2007 | 11:01 AM
zkiller's Avatar
zkiller
Use an add-a-circuit in the fuse box. There are two or three unused switched fuse spots. Then run a wire from there.
Old Sep 20, 2007 | 12:46 PM
moosestang's Avatar
moosestang
ORIGINAL: zkiller
I checked some of those with a test light and wasn't getting power in on. Does anyone know a place that sells those add a circuits for a decent price? They want some $4+ at my local discount. That is F'n crazy!
Old Sep 20, 2007 | 12:53 PM
hammeron's Avatar
hammeron
i purchased one at a Norvac Electronics store, not
sure if they are on the East coast tho....
Old Sep 20, 2007 | 12:54 PM
Stkjock's Avatar
Stkjock
Retired Mod
come on.....be a sport for $4
Old Sep 20, 2007 | 01:01 PM
moosestang's Avatar
moosestang
You know it cost them 20 cents to make that thing in China!
ORIGINAL: Stkjock
lincolnshibuya
Jul 5, 2020 03:05 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
