1st gear bouncing
Old Oct 1, 2007 | 09:49 PM
Ferrari0324's Avatar
Ferrari0324
Default 1st gear bouncing
I have a hard way of explaining it. But if I put it in 1st, and if I don't give it enough gas sometimes, it bounces and the whole car jerks back and forth, Until I hit the clutch and settle it back in,
Happen to anyone else? What is happening, slippage?
Old Oct 1, 2007 | 10:15 PM
craezjo's Avatar
craezjo
Default RE: 1st gear bouncing
does it happen right when you start the car and try and drive it
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
sounds like your bogging out, and need to give the car more gas. dont worry, not everyone can drive a stick at first
Old Oct 1, 2007 | 10:17 PM
howarmat's Avatar
howarmat
s197 Junkie
haha....i was going to say learn how to drive a stick......i didnt want to sound like an *** though
Old Oct 2, 2007 | 09:44 AM
acascianelli's Avatar
acascianelli
Since I suck at driving, I still have my car do this every once in a while. It happens mostly when the car is cold. You're either not giving it enough gas, releasing the clutch too quickly, or a combination of both.
Old Oct 2, 2007 | 10:13 AM
ski's Avatar
ski
A dirty throttle body and/or MAF sensor may also be the cause.
Old Oct 2, 2007 | 12:19 PM
thaztrain35's Avatar
thaztrain35
im pretty sure its the driving... i used to do that when i first got my car... dont worry.. just drive n ull eventualy get it
Old Oct 2, 2007 | 01:40 PM
22kart22's Avatar
22kart22
wheel hop?
Old Oct 2, 2007 | 06:16 PM
Aziraphale's Avatar
Aziraphale
If I drive mine right after I start it up without giving it a couple seconds, sometimes it will jerk a little bit AFTER the clutch has been released and only at low speeds.. Is that what you're talking about (yes, plenty of gas, it's at 1500rpm or so)? I've heard a couple other people on the board have the same problem. If you let it run for a minute then you'll be fine.
Old Oct 2, 2007 | 06:21 PM
22kart22's Avatar
22kart22
I find that when my engine is very cold, the throttle is super-sensitive.
It's comparable to a bad manual-transmission driver. Just jerky no matter how you drive it.
